This is home for everything related to AI agents, automation, and the systems that power them. Whether you’re designing agent architectures, configuring automation platforms, or just want to show off something cool you made, this is your spot.
The agent space is moving fast. New protocols, new frameworks, and new platforms are launching constantly. This is the place to keep up, share what you’re learning, and connect with others who are building in this space.
What belongs here:
Architecture & Development — Agent design patterns, multi-agent systems, frameworks (LangChain, CrewAI, AutoGen, Semantic Kernel), protocols (MCP, A2A), context engineering, memory management, building custom tools, debugging and evaluating agent behavior.
Platforms & Configuration — Agent products and automation platforms you use and configure (n8n, Make, Zapier, Relevance AI, Flowise). Sharing setups, comparing platforms, troubleshooting, tips and tricks.
Showcase — Built an agent? Show it off. Share what it does, what you used to build it, what went well and what was tricky. Demos, screenshots, and walkthroughs are always welcome. Don’t wait until it’s perfect.
Use tags to help others find your post: architecture, showcase, platforms, or any of the specific tool/framework tags.
